Call Forwarding to external # via SRTP Gateway
Battman
Good day. 1st time poster.
I am Call Forwarding (Call Routing) to an external cell phone via a sofia gateway.
This works perfectly with an unencrypted gateway. No issues with the Dial String that is created by FusionPBX for the extension.
However, when the gateway is set up with encryption (SRTP), the extension's Dial String is a bit lacking. I have to add the following to the dial string for the extension,using the superadmin account .
rtp_secure_media=true,zrtp_secure_media=false
After that all works just fine.
This solution will not work, however, for end users that modify their Call Forwarding settings on demand without the assist of a superadmin.
Now I could modify "call_forward.php" and add the additional dialstring code statically. But that would force that behavior on all gateways/domains. Its really not an ideal fix. Not too familiar with the FusionPBX framework, so the question is....Is there a better way?
Any suggestions would be appreciated..
FusionPBX 4.2.2
FreeSwitch 1.6.19
