ACL and Trunks
Arsenal Solutions
Hi everyone,
I have a FusionPBX install with a trunk (Gateway) registered with a provider. I can make external calls but for incoming calls (port 5080) the PBX sends a "407 Proxy Authentication Required" after the "INVITE" from my provider and I see "Rejected by acl "domains"" in logs. I was under the impression that you only need to modify the ACL when unsing a trunk with no registration. Am I right or do I have to add my provider to the "domains" "Access Control".
Also, regarding ACL, I see in the documenation for "Access Control" this statement:
"Do not put your public ip or phone IP addresses in the domains access control list."
If I look in the "domains" Access Control I see that my public IP was somehow automatically added and allowed. Is that a normal behavior?
I have my public ip in the 'domain' field, Where you need to put your carriers is in the 'CIDR' field.
