488 on reception T38 re-invite
Kwekkel
I send an outbound fax call and after call establishment the remote party sends a T38 re-invite.
The response is 488 Not acceptable here.
Any ideas/suggestions?
Thanks.
413
What is generating the 488, is it FreeSwitch or an endpoint?
Most often a 488 occurs when there is no codec intersection between the endpoints.
Check you have t38-passthru set to true and enabled in the relevant SIP profile.
