I just started using Amazon's Chime Voice Connector for VoIP service. Amazon's service doesn't have INBOUND CNAM lookups (yet). The least expensive way I've found to add this is using BulkVS ($0.002 per lookup as of this writing). This is also cheaper than my old provider (Vitelity at $0.009/lookup)
Here's a guide I made for reference. It will likely work with other providers too by changing the URL in the cidlookup.conf.xml file in Step 2 below.
First Register for an account at: BulkVS (click signup for new account)
Step 1: In FusionPBX, Ensure that the CID Module is enabled and running.
Go to: Advanced > Modules. Look under Applications for CID Lookup and Ensure it's running like this:
Step 2: Login to the Terminal into your FusionPBX Server. You'll need to edit the Config:
Now delete all the text in there and add this code, you will replace YOUR_API_KEY with the one from BulkVS.
See for API Key: CNAM > CNAM Instructions > CNAM Methods > CNAM HTTP/HTTPS Instructions
Step 3: Create a Dial Plan. Click your specified domain then Dial Plan > Inbound Routes. Create a New Rule exactly like this:
Now, you are all done. I recommend restarting freeswitch from Terminal:
root@pbx#: cd /etc/freeswitch/autoload_configs/
root@pbx#: cp cidlookup.conf.xml cidlookup.conf.xml.orig (note: make backup of current in-case of problems)
root@pbx#: nano cidlookup.conf.xml
<configuration name="cidlookup.conf" description="cidlookup Configuration">
<settings>
<param name="url" value="https://cnam.bulkvs.com/?id=YOUR_API_KEY=${caller_id_number}"/>
<param name="cache" value="true"/>
<param name="cache-expire" value="86400"/>
</settings>
</configuration>
root@pbx#: service freeswitch restart
