2 CDRs for call forwarded calls
Roget Hoffman
17
Hello
I have a need where in the event a call is forwarded, the result is two call records. One for the inbound -> ext, and one for the outbound ext->call forwarded number. I has turned on leg-b to true in xml_cdr.conf, but when I do that I get 2 CDRs for ALL calls. Not what I want as my CDR data is sent off to a billing system.
Does anyone know if this is possible and how to do it?
thanks in advance
simcard
Seeing the same issue here; after going the freeswitch lists and numerous google searches we've yet to be able to find anything in fpbx/freeswitch that will merge these records when leg-b is true.
We still have leg-b set to false, however we've taken to combining and normalising these particular cdrs into one record before we import the cdrs for mediation and rating.
Not ideal, however, like you we preferred the single cdr approach. You could just write a script in your favorite language to find cdrs that match each other, produce a new combined cdr and discard the a and b leg records for billing purposes.
Roget Hoffman
17
Thanks for the reply, however I'm not sure if I was clear on my issue.
Normally, (when a call is placed outbound - or - a call is received inbound (a normal call) - the result is 1 CDR. that's all good, - example: ext 100 calls 555-555-1212 or 555-555-1212 calls in, the CDR shows the "source" and the "destination" correctly.
like this:
direction source destination
inbound 100 555-555-1212
or
outbound 555-555-1212 100
However, if ext 100 has a call forward turned on, lets say (forward to) 555-555-9999. Then 555-555-1212 calls in - i still get 1 CDR where the source is 555-555-1212 and the destination is 555-555-9999 - and the CDR does not show ext 100 anywhere in it.
this is what I see now:
outbound 555-555-1212 555-555-9999
Since i have a requirement to show "both" the inbound side (555-555-1212 -> calling ext 100) as an inbound call, and another CDR showing ext 100 going out to 555-555-9999 as an outbound call.
what I need is this:
inbound 555-555-1212 100
outbound 100 555-555-9999
Wasn't this the default Fusion behavior at one point?
thanks in advance!
