[Tutorial] Csync2 for Filesystem Replication
640
On each node ensure that the remote node is accessible via the hosts file for the short name.
They do not need to be resolvable externally so in our lab case we will simply add node1 and node2 to each file:
So modify /etc/hosts to suit you IPs and chosen names.
Add for example:
79.137.83.17 node1.local node1
79.137.83.18 node2.local node2
Check both hosts are pingable by short name:
root@vps367591:/usr/src/fusionpbx-sce-install/debian# ping node1
PING node1.local (79.137.83.17) 56(84) bytes of data.
64 bytes from node1.local (79.137.83.17): icmp_seq=1 ttl=64 time=0.104 ms
root@vps367591:/usr/src/fusionpbx-sce-install/debian# ping node2
PING node2.local (79.137.83.18) 56(84) bytes of data.
64 bytes from node2.local (79.137.83.18): icmp_seq=1 ttl=57 time=0.562 ms
On each node edit /etc/hostname and set to your node name as set in the hosts file, eg:
One node1:
echo node1.local > /etc/hostname
One node2:
echo node2.local > /etc/hostname
Then reboot
On each node:
apt-get update
apt-get install csync2
On node1 generate the needed key files:
openssl genrsa -out /etc/csync2_ssl_key.pem 1024
openssl req -batch -new -key /etc/csync2_ssl_key.pem -out /etc/csync2_ssl_cert.csr
openssl x509 -req -days 3600 -in /etc/csync2_ssl_cert.csr -signkey /etc/csync2_ssl_key.pem -out /etc/csync2_ssl_cert.pem
csync2 -k /etc/csync2.key
On node1, edit /etc/csync2.cfg remembering to change host to suit your node names and make it like so:
# please see the REAMDE file how to configure csync2
group ClusterSync
host node1.local;
host node2.local;
key /etc/csync2.key;
include /var/lib/freeswitch/recordings;
include /usr/share/freeswitch/sounds;
include /var/lib/freeswitch/storage;
exclude *~ .*;
Now copy the csync config, certs and keys to the other node, in my case:
scp /etc/csync2* root@node2:/etc/
On node1 now do:
csync2 -fr /
Follow this with:
csync2 -xv
Now repeat the above again:
On node1 now do:
csync2 -fr /
Follow this with:
csync2 -xv
This will take a while as it is an initial sync and will be verbose.
If anyone knows why we need to run it twice, please comment.
On each server do crontab -e and set up a job to suit you, I use:
0-59/2 * * * * /usr/sbin/csync2 -x
on one server, and on the other:
1-59/2 * * * * /usr/sbin/csync2 -x
This means each minute, one server syncs then the other on the second minute, seems to work great for me.
If you wish to test:
On node one:
touch /var/lib/freeswitch/recordings/test
Give it a couple of minutes then on node two you should see the file:
ls /var/lib/freeswitch/recordings/test
root@node2:~# ls /var/lib/freeswitch/recordings/test
ls: cannot access /var/lib/freeswitch/recordings/test: No such file or directory
root@node2:~#
Now remove the file from node two and give it another couple of minutes:
rm /var/lib/freeswitch/recordings/test
One node one:
root@node1:~# ls /var/lib/freeswitch/recordings/test
root@node1:~#
All done :)
Csync2 is a very powerful tool and we have only touched the surface here. For example actions can be triggered upon file changes etc.
I encourage everyone to read http://oss.linbit.com/csync2/paper.pdf and if you do come up with any weird and wonderful configs, please share them with the community.
Reactions: paradym and ppwicho
You wouldn't need to do this with csync, the db replication already takes care of that.
I tried this procedure:
1. i created an extension on node1
2. node1 with postres user: pg_dumpall -U postgres > /tmp/all.bak
3. scp copied all.bak to node2
4. nod2 with postreg user: psql -f /tmp/all.bak postgres
Then i had a connection problem with fusionpbx webinterface (wrong username)
5. i copied from node1 /etc/fusionpbx/config.php $db_password to the same file on node2 and web interface become available but i can't find the extension. Instead now i have all menu duplicated like attached.
Any idea? Thank you.
I would guess at that you are using some cloud based vps. There will likely be some sort of cloud init, this is definitely just some mundane linux problem that the solution for doesn't lie here.
You are right problem fixed thanks
Hi - Ive run this tutorial before and had it working. Ive just set this up again but on running the first sync i get the follwing errors: -
ERROR from peer node2.local: Identification failed!
While syncing file /var/lib/freeswitch/recordings:
While syncing file /var/lib/freeswitch/storage:
Finished with 4973 errors.
Any ideas welcome. Ive ensure hostname are perfectly set and files on both are identical.
Thanks in advance!
Thanks in advance!
did you run sync twice
